defrost timer location
Where is the defrost timer located on this fridge
Here is your parts breakdown
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=122277&diagram_id=273425#d273425
The defrost timer is Item 23 in Section 3
It is in the control console.
There is usually a hole in the bottom of the console so that you can turn the timer cam and force a defrost cycle.
thanks for the info
