Hello,
My freezer is working but my refregirator gets warm. I tried to locate the defrost timer to test it but I could not find it. please advise! thanks,
Tarik
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gs5shaxnb00
See the attachment for the tech sheet
You do not have a defrost timer, defrost is controlled by the main control board (Item 18 in Section 11).
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle, see the tech sheet when the fans and compressor turn off you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Section 11) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. It seems it is missing from the parts breakdown but there will be one clipped to the evaporator coils.
If both the above are OK then odds are the control board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
Thank you Denman, I will need to replace the electric board. Is it easy to change?and what is the process? thanks again for you advise
Tarik,
Should not be that difficult though I have never done one.
Just be sure to unplug the unit.
Also touch a ground before handling the board to get rid of any static electricity your body may be holding.
If you has copper plumbing pipes then one of them will do.
Whirlpool Gold refrigerator model GS5SHAXNQ00
The freezer side is working fine, refrigerator side will not cool and is warm. Took cover off inside freezer, ice and frost on coils.
Have no idea how to check if defrost thermostat is bad or how to manually put in defrost mode
Any insight would be greatly appreciated
fyrestiks
http://www.appliancepartspros.com/parts-for-whirlpool-gs5shaxnq00.html
The procedure to force a defrost cycle is attached to my earli8er post. Your unit is the same.
