Dehumidifier only runs a few minutes
If I take out the water bin and push the inside red button and hold it the dehumidifier will run. When I replace the bin it runs for a few minutes then shuts off and does not come back on. There is no sign of water but it’s only running for a short time.
I’ve cleaned the filter but not sure what else to check.
check teh float switch to be sure that it is operating correctly and unobstructed
:cool: check teh float switch to be sure that it is operating correctly and unobstructed
