The manufacturer didn’t attach the (plexiglass?) film on the inside of my Kitchen Aid microwave door, so the spatter goes through the mesh and sticks to the glass, leaving me no way to clean it. How can I take apart the door to clean the glass. Looks like I can order the piece of film from you guys… but I need to clean the glass first! Obviously the manual doesn’t tell you how to disassemble the door
Disassembling the door is a fine art of using a putty knife and gently slipping it in between the inner and outer door panels to release several plastic tabs. Start on one side and work your way around the door. The inner and outer panels should separate from the metal and glass panel in the middle. It takes some time and you must be careful to limit the number of broken tabs, but there really isn’t any trick to it.
Dispensor on front will not work and when it does it will not turn off
