Dishwasheer
I Would Like Instructions On Removing The Control Panel On This Model To Repair The Latch Assembly
— Begin quote from GRAMCRACKER;443909
Gramcracker,
You don’t have to remove the control panel, you remove the plastic inner door liner.
Here are the instructions from the service manual,
[FONT=Arial][LEFT]Inner Door Panel[/LEFT]
[/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Removal of the Inner Door Panel will allow access to the Microprocessor Board, Door Switches, Detergent / Rinse Aid Dispenser, and Vent Assembly.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][B][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Removal
  1. Disconnect power to the machine.[/LEFT]
    [/B][/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]2. Open the Dishwasher door.
  2. Remove the 11 Torx™ screws along the sides and
    top of the Inner Door Panel.[/LEFT]
  3. Separate the Inner Door Panel from the Outer Door.
    [FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]5. Disconnect wires from the Vent and Dispenser Wax
    Motors before pulling the Inner Door Panel away[/LEFT]
    from the Dishwasher.
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]1. Disconnect power to the machine.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]2. Remove the Inner Door Panel. (See paragraph Inner
Door Panel removal).
3. Lift Door Latch Assembly out.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][B][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Switch Removal
    [/B][/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]2. Remove the Inner Door Panel. (See paragraph Inner
  2. Remove Door Latch and Switch Holder Assembly.[/LEFT]
  3. Depress locking tabs and lift switch from holder.
Good Luck,
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
