This is called a Maytag Jetclean EQ +
The unit stopped abruptly during the dry cycle and doesn’t respond except the Heated dry & Clean lights blink. If I press the drain button, it will try to pump and then go back to blinking.
About 2 years ago I replaced the control board and its worked fine until now.
If it is a control board again, is there a chance that a board from a Maytag model MDB9150AWB would fit it?
