Will not clean the dishes in all the cycles and their is little water residue.
Thanks Gene,I’ll give that a try and let you know what happens.
With much gratitude,
Matt
Hi there!
Need some help on repair of this dishwasher. The motor started making whining noise and needs to be repaired/replaced. There is nothing unusual in the chopper or pump area so it has to be the motor. Sounds like going bearing. I am familiar with the electrical motors and will try to repair it first. The question: is it possible to remove the motor-pump assembly on this model from the inside or I need to take the dishwasher out? Thanks in advance!
Val
