The dispenser no longer locks and I need to replace it. I have the part and would like to find out how to do it. I’m assuming I take off the outer door and would then have access to the dispenser. Does anyone know if there is a repair manual available?
Here is a manual, although not for your unit it should be close to yours.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548?OpenDocument
One thing to note is that I do not think you have a rinse aid sensor so you do not have to worry about it.
Thanks! That was exactly what I needed.
