dishwasher does not drain completely. removed and cleaned. unit drains out of cabinet. drain line open. nothing obstructing check flapper.is pump the problem?
I have the same problem. Replaced the drain pump. Did not fiix the problem. Suspect the controller.
— Begin quote from gnthrush;234638
Thanks wonder how u check controller?
