I have an Amana dishwasher that we purchased two years ago. The door handle busted and I can not open the front door. The dishwasher will not slide out because of the mounting screws along the trim and the uppper two brackets to the counter. Any idea how I get this open?
I think the same thing happened to us. We are able to open our door by leaning down pretty hard on the top edge of the door (that releases the latch) and then pull forward. We have been operating that way for about a month. I ordered the replacement part and now am having trouble detatching the old handle. Part was about $30 on the internet.
The "Lock On" light will not clear. I have pressed the "No Heat / Dry" button for the stated 4 sec. to clear, disconnected power (up to 12 hours) and checked all connections on Control Board and it will not clear. "Cancel" button works and only causes "Cancel" and "Lock On" lights to blink.
Is there a way to determine an error code or clear error? I assume Control Board may be bad, but the Control Board (Part #: 9744031) from "Sears On Line" says it is "discontinued" and replacements are not available… or is it possibly a bad pad on the "Console Assembly" (Part #: 3384236, almond)?
Thanks in advance
