dishwasher fills with water from sidewall inlet
My dishwasher will continuously fill with water from side wall inlet. Is the problem in the water inlet valve at bottom of washer or in the valve on the side of the wall where water is coming out off.
dishwasher fills with water nonstop from sidewall water inlet. is this a problem with sidewall valve or water inlet valve at bottom?
Hi.
If the water continuously coming into the dishwasher when the door is open, you have a bad water inlet valve W10158389
When replacing the valve be careful not to break the shot off valve under the sink. That could be a problem!
Here are the breakdown diagrams and http://www.appliancepartspros.com/fill-overfill-parts-for-whirlpool-dul240xtps7.html
Thank you.
Simon.
