I have edited this to ask for some help in trouble shooting if I need a new front panel or control board inside… A few days before this acted up, I removed and cleaned some of the inside parts above the motor… we have very hard water… The motor did come loose and a little water leaked on it until I pressed the seal back down… Could that have hurt the motor to cause this?
Also in connection with the info I posted below… When I press any of the Wash buttons and then press Start, the "Normal Wash" and "washing" LED light just faintly light up. Would that be a problem more with the Control board inside or the front panel?
Press "Normal Wash" + "Start" = faint "washing" & "Heated dry" lights show.
Washer will not start.
Press "Rinse Only" and it lights but press "start" and after 15 sec all turn off
Press "Light Wash" button and "Long Wash" and Press "start" and faint "washing" light but all goes off after 15 sec.
I have replaced the front control panel/lights in August 2010 while still under warrantee. Could it be that again?
