dishwasher impeller installation
Can the impeller kit assembly be installed from the interior of the dishwasher, or do I need to pull it from under the counter for this part’s removal and replacement? I previously removed and replaced chopper assy which did not eliminate noise during wash cycle (no noise during draining). Are there any other seals besides those in the impeller kit assy recommended if replacing this item?
Hi timoteo,
In order to rebuild the pump the dishwasher has to be removed from the cabinet.
You can find the complete instructions in the [AP3039198](http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf"]tech sheets[/URL].
Besides the impeller kit you have to order the volute seal.
Here are the break down diagrams for the Whirlpool dishwasher http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=132388&&model_id=504547
Hi Tim,
I can not believe it but the motor assembly cost less than the motor itself. So, if the noise caused by the motor bearing I would buy the motor assembly. Definitely you do not need the pump housing in any way.
