Dishwasher keeps running
Dishwasher starts & runs normally but never drains the soapy water out. It has run over 2 hrs. without shutting down. I open door, hit cancel & shut door and it pumps the water out & shuts down. Checked the water temp at 118 degrees which should be good. All the valves & pump seem to work okay so I wonder if the control board has a problem.
Gene,
I will keep you posted-I will have to order the control board. I noticed in one of your other threads that you mention tech sheets. Where can you find the for Kitchen Aid D/W?
Thanks,
Mike
