My portable dishwasher has a slow but steady leak coming from the metal piece at the top of the motor. Out that hole I drew the arrow pointing to. Water pools above it but I can’t figure out how it’s getting there. I see no other drips or water anywhere other than here. The hose above it seems free of leaks and I’m pretty sure it’s coming from the motor shaft as well.
It leaks the entire time that it’s running, and continues to drip for some time after it’s shut off.
Your model no. is still missing three numbers. Luckily I’ve had 26 years of experience with Kenmores. I added "665." to the front and came up with the kit part number.[SIZE=1]model no. 665.1777581[/SIZE][SIZE=1]
[/SIZE]
Hopefully your motor shaft won’t be half rusted away. It happens sometimes when the impeller cracks and it leaks for a very long time before being noticed.
