Dishwasher motor--need to confirm bad drain winding
I did a resistance check on the wires to the motor (Part 3369330) and found near 0 readings on the White & Blue to Yellow (wash cycle) connectors but very high resistance on the White & Blue to Black (Drain cycle) conncectors.
Does this confirm that the drain winding of the motor is defective?
The dishwasher does not drain properly–everything else I checked is working OK, so that left only the motor or timer to be the problem.
If my assessment is correct, I assume that the motor can not be fixed but must be replaced–is that right?
Thank you,
Bob F
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=665.1661591
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
I am doing a bit of guessing here that your unit would be a close match.
See page 38, it shows the drain winding as 4.2 to 7 ohms.
Yes the motor will have to be replaced.
I cannot explain it but it looks like the motor/pump assembly is cheaper than just the motor.
Click on the below pictures for more info.
AP3776340
AP3044452
