Dishwasher motor repair
I have a Kitchen aid dishwasher that will not wash. Replaced the motor assembly, but still will not wash. Tub fills then float clicks. Motor relay kicks in on circuit board, but motor does not run. Checked thermal fuse and it is not open. Do not want to replace control board but do not know what to check/replace next.
Don
Hi Don,
Check for 120 VAC to the pump motor while it should wash. If the reading is incorrect, check all wires. If there is nothing wrong, replace the control board.
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-whirlpool-kudi02irbl0.html
