Front panel without any lights (dishwasher seems to be dead)
There is full power to the unit.
The Bi-Metal (Thermal Fuse) are fine.
The door switch seems fine (clicks and has power)
I’ve checked all connections and they seem to be in place
[COLOR=Blue]Does any on have any suggestions as to the problem other then the circuit board or front panel?
I am not sure how you checked them but just because they click it does not mean that the contacts in the switch actually closed.
I would remove power to the unit and check them for 0 ohms when closed.
Remove the wire to one side of the switch when measuring, this ensures that you do not read an alternate/parallel circuit path.
Also the parts breakdown shows you have 2 door switches so I am assuming that your "switch" was actually switches.
Denman, thanks for the quick response. Yes there are two switches. I have checked both of them and there is continuity. I also checked the Thermal Fuse and the High Limit Thermostat and they are fine. Should I replace the Control Board?
If you order it from AppliancePartsPros I believe you can return it if it does not fix your problem as you have done some troubleshooting.
Check out their return policy.
