Dishwasher noise
My dishwasher has started to make a extermely annoying whirling noise during the wash cycles. Does anyone have any suggestions on what might be wrong as it is hard to trouble shoot as the noise stops once the door is opened?
The first thing I would do is check the chopper (#6 on the diagram). You can find some useful information in one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/2903-whirlpool-dishwasher.html
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135653
Can this be accessed thru the main wash area or does it have be pulled out and accessed from them bottom?
Yes, it can. Just click on the above link and you will see all instructions.
Gene, thanks for trying to help. No, I have not checked the engagement at all. How can I do that? I am pretty handy as long as some guides me the first time.
Remove the chopper and check the center part of the chopper for any damage.
If there is nothing wrong, then the noise is probably coming from the motor.
Gene, Thanks again for your help. I removed the chopper assembly and started the dishwasher up. The noise was still there. So when all is said and done, I guess my next step is to order a new motor. All sounded normal while tub was filling up, one it started to wash, the noise was instant. After I replace the motor, I will do another post and with fingers crossed, all will be quiet.
Roger
Good luck.
Gene,
Finally ordered my motor and replaced it 3-2-2010. The noise is gone. Thanks for your help.
Roger
Gene,
Thanks for your help. I finally ordered and replaced my motor on 3-2-2010. All is quiet.
Roger
You are welcome Roger. I’m glad you were able to fix it.
