Dishwasher not draining
I’m having a problem with my dishwasher not draining/pumping water out. It is not a clogged or twisted line, and the line between the sink and the diswasher is clear. I’m thinking it’s something wrong with the pump, but don’t know how to tell if it’s the solenoid or what. Any help is appreciated. thanks.
Remove the toe panel and check the drain solenoid (#497 on the diagram). The plunger (#426) must freely move up and down.
Post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=21599825&&model_id=209236
