Dishwasher repair
I have a Kenmore dishwasher that has locked up on the front control panel & no manual. I’ve tried the cycling power to none effect. I know there is a sequence of buttons to push on the front panel to unlock it. Anyone know the sequence? Thanks
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Here is the info on the panel lock from the operator’s manual
"Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off."
You can get a manual from the following.
http://www.managemylife.com/
You will have to register but do not send out junk mail as long as you do not ask for it.
If it is not locked, try the diagnostics.
Check that both door switches are closing properly and that the wiring in the door is OK.
It could be you have a bad key (open).
The usual way to check this is check the keys with a meter, if all OK then odds are it is the control board and not the keypad at fault
Still a bit of a crap shoot but your odds are better.
You may also want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
