When we run the dishwasher in the normal full cycle if shut off after only being on 5 or 6 minutes. Then it flashes a PF error code. It will run thru a full "prewash" cycle with no problem. I have tried replacing the control bord/panel but it makes no difference. I have been told that it may be the drain motore, but that works fine in the "prewash" cycle.
