When I press the normal cycle start button it blinks and when I press the cxl button it blinks as well. The dishwasher will not start. I checked the drain motor, door switches, thermistor -all works and recently I replaced the electronic control board. What may be wrong?
HI.
Most likely you need to replace the control panel [part]8531239[/part]
If you got the control board from APP you may return it back (contact our customer service).
Here are the breakdown diagrams and Control Panel parts for Whirlpool KUDK01ILBS5 - AppliancePartsPros.com
Post the results.
Simon.
great, I ordered it
thank U much
You are welcome.
Simon.
— Begin quote from Simon / APP Team;798611
You are welcome.
Simon.
My kitchen aid dishwasher (2years old) (Model KUDS301VBLO)
has power but the start light blinks and wont work. Do you think i also need to replace the control panel? Is it the same part #? Thanks.
Hi.
If the start LED flashes 3 times when the botton pressed:
- The door has not been open between the cycles.
- Door switch stuck closed.
The door latch W10380262
Here are the breakdown diagrams and http://www.appliancepartspros.com/control-panel-latch-parts-for-whirlpool-kuds30cxbl0.html
Post the results.
Simon.
