The dishwasher clean light stays lite all the time, and it will not turn on. The light is on solid not blinking. Any ideas please help!
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5120295
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154457601.pdf
Sounds like the timer is toast.
I am assuming that you have moved the dial to other locations to see if it will do any thing.
