dishwasher wont spray dishes off
My dishwasher comes on . water evacuates out of machine , then fills with water . machine run a while then evacuates water out again . refils and runs a while and repeats the same procedure until time is complete . the problem is that the water does not spray out of the top star like sprayer and weakly comes out of the bottom star sprayerwhen I open the door to observe the cycles . the dishes will not get clean on top or bottom . I replaced the circute board and it did not change anything . the element get hot and water . the soap dispenser open but the soap does not get washed out . what could be wrong. puzzled
start at the bottom spray arm and take it apart going down clean everything out, filter and all, down to the motor if that doesnt help spray motor is getting weak
I ve cleaned all the way down to motor . and had no improvement . there is not a specific spray motor part in the manual . what other name for the part would i need to replace ? Are you talking of the main pump attached to the motor? thanks Puzzled
Turn off water to the unit and strip down to the motor impeller including removal of the 1/2 round impeller cover, just remove screw and pry off.Sponge out all the water.
If the chopper screen is clogged, remove and clean it, put it back in and turn the unit on. Observe with the door open if the chopper shredder is moving. If not,you need to replace the chopper AP3039186 and the check valve imedded in the housing AP3175191
Instructions on how to replace tubing (P/N AP4098196) for the pilot light?
What i there to say here but, find one end of the old one, and find the other end, and remove it, and replace with the new one. Shut the gas off before you start, and unplug the oven!! Tom http://www.applianceeducator.com
— Begin quote from kayakcrzy;161537
What i there to say here but, find one end of the old one, and find the other end, and remove it, and replace with the new one. Shut the gas off before you start, and unplug the oven!! Tom ApplianceEducator.com
The line goes behind the back wall of the oven - do I have to pull the oven out? Is the back wall of the oven removable? Can I fish the new line thru the opening of the back wall?
Unfortuantly, you will most likely have to pull the oven, because the gas line will hook up to the gas valve. Did you take the bottom of the oven floor out to see if you can fish it through. If not, the oven has to be pulled. Tom http://www.applianceeducator.com
