turned circuit on,and the normal load key flashes but won’t start.hit cancel key and the normal key and rinse only key flashes. if you hit cancel again 2 dashes apear in the status window,hit cancel again and the 2 dashes go away. thanks in advance for any help.
Here are your parts[I]
[https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf](http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=kuds01ijbs0"]Replacement parts for WHIRLPOOL KUDS01IJBS0 | AppliancePartsPros.com[/URL]
[/I]Here is the tech sheet
[URL="https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf)
Also here is a service manual, not the greatest I’ve see but may be of some use
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
Sounds like either the control board or the key pad is difficult to confirm which it is, so best way is to check the keypad, if OK then by default it is probably the control board.
Could be a stuck key
Try to run the diagnostics
Check the keypad with a meter for the stuck key
If it is a stuck key the keypad will have to be replaced,
Could try cleaning the connector but this usually only applies to opens not shorts (stuck key)
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
Am off to the lake today so will not be available till Monday/Tuesday but there are many other on this forum who can give additional assistance if needed.
