When you push the normal cycle button the lock light comes on.
When you push Pots&Pans or Heat Dry or Lock buttons, all the status lights come on.   Then when you push start&reset all lights go off.
Pushing normal or pots&pans is the only buttons that will make any lights come on.  What part do think I need?
Control Assembly or Sequence Switch?
