Dishwasher
The top rack is not getting clean. The arm under the top rack is producing a weak stream of water and it is not spinning at all, the little thing on the ceiling of the dishwasher is not spraying any water at all.
I disassembled the top and bottom arms, I dont see and blockages or leaks, there just seems to be lack of water pressure to reach the top.
How can this be fixed?
Thank you!
Hi.
Your problem is most likely is a clogged chopper screen
[part]W10083957[/part]
It’s located inside the pump sump housing.
Here are the breakdown diagrams and Pump and Motor parts for KitchenAid KUDS30IXSS0 - AppliancePartsPros.com
Simon.
Thanks! I cleaned it out and indeed it works. Who woulda thought…:slight_smile:
You are welcome.
Simon.
