dishwasher
the control panel started to not operate properly. if you pushed certain buttons other ones lit up and it would run whatever cycle it wanted to and it would keep cycling over till i would shut the power off. if you pushed the drain/cancel button you could hear the pump running. but that is all it would do consistently. now it won’t operate at all.
