after wash complete number 9 flashes for awhile then goes off then comes back on. i have turned breaker off and back on, no affect
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mdb8600aws
Here is a service manual and a some tech info
http://www.servicematters.com/maytag_library/docs/16021814.pdf
http://www.servicematters.com/maytag_library/docs/16026390.pdf
http://www.servicematters.com/maytag_library/docs/TDD-0008-S.pdf
I have not seen this and cannot find any info on it.
Hopefully someone else has a solution for it.
I would run the diagnostics and see what if any problems show up.
Sounds like it may have something to do with the turbidity sensor.
Not quite sure of the problem.
The unit completes the cycle (dry and everything), then 9 flashes and then it starts a new cycle.
Is this correct?
I have run the field diagnostic test described in the info you sent. the test completed succesfuly and seems to have cleared the memory from the flashing 9. thanks for your help dan12
