After finishing the cycle, the water came up agin in the tub,I already checked the hose (attached to the garbagge disposal), is working fine, I do not what else to do.
Remove the filter frame (#543 on the [B]Replacement parts for General Electric GSD4200J00WW Dishwasher | AppliancePartsPros.com. Unscrew and check the piston & nut assembly (#564).
You can find more information in one of our previous threads: http://forum.appliancepartspros.com/dishwasher-repair/17125-triton-dishwasher-wont-drain-fully.html
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218471)
Thanks.
I tried that there is no problem with the piston, the water is still in the tub, the pipe connected to the garbagge disposal is ok because the water flows good!
How can I check if the water valve is working, because the tube is full again and thet water came trough that line and the water is hot.
Sorry for the delay.
I’m afraid I did not get clear what is wrong with your dishwasher. It does not drain properly or it keeps filling with water when the dishwasher is off?
If it keeps filling with water while the dishwasher is off and the door is open, replace the water inlet valve. No doubts about it.
Thanks,I will change that part.
You are welcome. Keep us posted.
Thanks Gene my Dishwasher is working like a new one!!!.I could replace the inlet vale and it is working !!
