Dispenser Door Panel
The door panel that controls the ice and water dispenser has stopped working. The icemaker still works, and the lights still come light up on the panel, but nothing happens.
The model number you posted is incorrect. Verify and repost it please.
Sorry, Model PSS26SHRC
Open the dispenser (the instructions are attached) and check the parts inside, including the micro switch (72 at the [B]diagram[/B]).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5223917
You’re a genius, Gene! Thank you so much - first time I’ve had crushed ice in months.:slight_smile:
You are welcome. I’m glad it’s up and running.
