dispenser dosn't dispense water does ice
i have an amana fridge, i moved it from florida to virginia. the water and ice always worked. i hooked it up in virginia, the water no longer works at the dispenser the ice maker and dispenser works fine. i’ve replaced the filter. i have water at the soleniod / valve in the bottom back area. i used an air gun to verify air travels to the front under the freezer door. then to the dispenser from the bottom of the door. i don’t notice any clicking noises from the valve when the dispenser switch is pushed. how do i tell if the valve is working.
thanx,
wayne
