Dispenser not getting any power
The ice dispensing tab broke on our dispenser today. I was trying to see if I could repair this. I unplugged the refrigerator, and removed the front plate of the dispenser. When I removed the plate, a 10 pin connector from the plate to the dispenser unplugged. When I was putting the plate back on, I reconnected the 10pin plug (that was the only thing that was disconnected). But now the dispenser does not work at all-no lights, no ice, no water. I don’t know what to do here-I really cannot afford a repairman at this time. any ideas what went wrong, and how I can repair it?
Bob T
Frigidaire side by side model FRS23HF5AW5
— Begin quote from BobT;148072
Bob T
Check door safety switch ( light switch ), loose/off wire, ribbon cable for front buttons off/loose, bad board. Well, I did find out that the light bulb was broke off up inside of the dispenser, I replaced it and there is still no power to the door or the light. So it looks like when the light bulb blew out (before I owned it) a small fuse in behind the dispenser panel had blown. After removing all the tiny screwe and the removal of entire front panel I found this little dead fuse. I had to take a butter knife to pry the box open where the ribbon cable plugs in. In there you will see a tiny fuse. Test it! After replacing that fuse everything is working fine. I presume this fuse is a safety feature to prevent electrical shocks because that dispenser panel carries 120v into it. Next to all of that 120volts is flowing water and a light bulb. I hope this helps you.
