display dead after power failure
We had thunder storms one night with power flickers and failures; which took out my oven. There is nothing on the display and it does not beep when any of the buttons are pressed, it is completely dead. I have made a few repairs to my oven previously. Can you make any suggestions as to what part/parts might most likely be the culprit? I know where I can get my control board repaired, but I am sure that there are other parts i should check first. Thanks!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KEBS208DSS8
Below is a tech sheet
http://forum.appliancepartspros.com/attachments/oven-repair-including-ranges-cooktops/3325d1308837362-worth-buying-kebs208.pdf
I cannot get one for a single oven but it will be basically the same.
Check that the power at the unit is OK.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the unit
L1 to L2 should be 240 volts
LL1 to Neutral is the side that powers the control board.
If OK remove power from the unit and check the power supply fuse, should be 0 ohms
It should be close to the control board.
AP3777386
If OK check the power out from the control transformer.
If OK, odds are that the control board is shot
If OK
denman said:
AP3777386
If OK
Thanks! The problem is the Control Transformer. I do not see this part in the schematics, unless it is one of the transformers listed in the "05 - Top Venting Optional" diagram. Can you please provide me with the part number for the Control Transformer, or will I need to go to another vendor?
It should be either item 5 or 7 in section 05.
I am not sure which one is but should have red and blue wires going to it.
