does not work
washer does nothing does not fill with water or start
Check if there is 120VAC at the power outlet. Check the power cord.
If there is nothing wrong then check for 120VAC between the "V" wire at the water level switch and neutral (remove the "V" wire from the terminal prior to test) while the timer is in "on" position.
If there is 120VAC then the water level switch is bad and has to be replaced.
If there is no 120VAC then the timer is bad and has to be replaced.
Here are the break down diagrams for the Whirlpool washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=5911&&model_id=235346
Did you run any tests from the previous reply?
