doesn't do cycle or allow dianostics
Hi guys, I have a GE front load washer that when I push the start button it takes about 20 sec. and starts to drain (even though no water) and runs two or three minits and then starts blinking pause/start. After awhile it stops. It won’t start a cycle or put any water in and won’t allow a dianostics test. There are no error codes either. I have a mini manual but it’s not very helpful. I was wondering if a bad door switch could cause this. Lots of corrosion around contacts on door switch. Any ideas
Ron
