don't spin
HI there,I have a roper washing machine and it will not spin,it will fill up and agitate but when it comes to spining,it will just stop,can anyone tell me what the problem might be.thanks
Check your lid switch. The screws holding it in place may have come loose or broke loose and now the lid is not actuating the switch.
Can Anyone Help Me My Roper Washer Wont Agitate Or Spin An Is Making A Noise… I Had To Move The Button An Hold Down The Lid Button To Drain It… I Think It Was Over Loaded. Would You Know What Is Wrong. Thank You The Model No Is Rax4232kq0
The first thing I would do is check the motor drive coupling (13 on the diagram).
You have to remove the cabinet and,then the pump and the motor. The instructions are attached to the post.
Here are the break down diagrams and the parts list for the Roper washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=123344&&model_id=263613
Thank you very much Gene on piece of the coupling was cracked.
You are welcome. I’m glad it was a simple problem.
Turn on oven will not start, Tap on safty valve, starts run 30 secounds and shuts off. Broiler works , runs off smae valve dual solinoid, stove top works:rolleyes:
