the door won’t close all the way and lights stay on.
I took the door off and tried to re-seat it but it still won’t close all the way up top.
Do the springs just get weaker? can i add a washer in there to tighten them up?
or do i need to take it apart and maybe add a spacer on the stove side of the receiver…
Anyone else having this issue with kitchenaid doors?
[COLOR="Blue"]
Do the springs just get weaker?[/COLOR]
Yes they can.
I would replace them as long as te hinge receivers look and feel OK.
They are item 10 in section 03.
There are two types so be sure you get the correct ones.
You could try but it ould be a bear of a job.
[COLOR="Blue"]
or do i need to take it apart and maybe add a spacer on the stove side of the receiver…[/COLOR]
Not sure what this would do.
