Door won't close unless pushed
What do I need to order to get the door to close without having to push it closed:mad:
Once the door is closed, if you insert a dollar bill between the gasket and door trim, will it slide out easily. If so, you probably need a new door gasket.
If ok, I would check the door cam on the bottom of the hinge. If ok, check the hinge side of the door gasket for a badly deformed surface. If bad, you can smear some vaseline on it.
