Error Codes: E6+F2. The display initially went blank. Turned power off to unit. Waited several hours, turned power back on. Display returned with PF code. Reset clock and all worked temporarily. Within an hour the display went blank. The unit would beep at approx 30 miniute intervals if power to unit left on.
BIG QUESTION: How do you access the control panel?
An E6-F2 error message is suppose to indicate there is a problem with the cancel key of the keyboard. That is most often due to a problem with the control panel but can sometimes be caused by a problem in the electronic control itself.
