dr and codes
I have a Frigidaire Affinity AGQ7000ES1.
The dryer has stopped spining after a minute or so and saying ‘pau.’
When I try to restart it it says ‘dr.’
When I press start again it will run for a few seconds and repeat.
I replaced the door switch and lamp. Light comes on when door opens and the door latches securely.
I rain field test mode and got the following codes (corresponding to the light stack:
r06
E04
E4A 026
C01 00 925
186 791
086
Can someone explain these codes to me, I tried the Tech Data Sheet, but E04 and E4A don’t seem to be listed in there.
Thanks,
LoneStar:confused:
Anybody have an idea? I don’t want to buy a new control board unless I really need one, but since I have a new door switch (tested, confirmed working) I’m thinking it might be something board related.
after running field test mode again and confirming that the moisture sensor was working and the thermostat seemed functional I went ahead and replaced the control board. $150 and I have a known-good dryer again.
I know nobody is reading this post, but now if someone ever has a similar problem in the future they won’t be left high and dry like this.
