Drain motor doesn't run
My GE PDW 7880 dishwasher doesn’t drain. Checked all the obvious things: blocked drains, crud in the sump, etc… The drain pump will not run in the diagnostic mode - 5.3 volts to the motor. The motor ran once for a reset after I moved the connector to the control unit, but will not run again in any diagnostic mode. Do I need a new controller assy.? What else could I do to confirm my problem?
