The water dispensor has started to drip on my side by side fridge. Is there a fix for this?
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it’s just drips after use.
