I’m trying to replace a Drive Belt on my washer. When I took the front off and located the problem, the belt was already torn and laying there. I wasn’t able to descern the pathway of the belt. Does anyone no how the belt threads through pulleys and Idler pulley? Thx for you help
Put the belt around the motor pulley and the transmission pulley. Push in on the idler pulley and turn the belt on.
Here are the break down diagrams for the White Westinghouse washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=301220&&model_id=119656
