drive pulley
Hey All,
Concerning above mentioned washer. I was doing a bit of troubleshooting and removed the drive pulley. I started to replace the drive pulley but, for what ever reason, I don’t have enough of the shaft sticking out to put on the retaining washer and clip. Any suggestions are most welcomed.
I would go to the web site, %url% for correct washer replacement info. Important you get the washers in the right order.
I have read you can stick a throw pillow on top of the agitator and force the lid down with a heavy object, this will force the spindle down to allow washer replacement. Post reults.
Sorry, but I have tried all that I have been advised and I am not able resolve this issue. I looked at the diagram to make sure all the washers are correctly aligned and cam properly set. It is if the shaft became shorter suddenly. Is there a way to release the shaft? :frowning:
Re-post your problem, maybe someone has more experience.
