Drum Hole Plug - Whirlpool Electric Dryer
My dryer stopped spinning, opened it up, belt is broken, have ordered replacement.
However, I found a small metal piece laying on the bottom, which I identified from your parts list as a Drum Hole Plug (#24 in Bulkhead, your part # AP3080776).
I don’t need to order the part, I just need to know where does it go? On the schematic, it’s just up in the air, no indication where it goes.
Any help you can give would be deeply appreciated, because if I can’t find out where it goes, I’ll be putting the dryer back together without the part - will that cause any trouble down the road?
BTW, I’m a 61 year old woman, unemployed and thanks to your videos, I had the confidence to take apart the dryer and will attempt to repair it myself, so thanks for that!
Regards,
Jan
