I have a GHW9200LW Whirlpool Duet HT washer. It makes a loud sound in the spin cycle. It looks as if the drum is tilted forward. The springs (2) are in place. The shocks (4) appear to be ok. Any ideas
I have the same issue and I found out you have to replace the whole outer tub which the bearing is a small part of (350.00+). Has anyone tried to just remove the Bearing? I have been told that it is possible.
