I recently purchased knob and clip assembly from you for my dryer as we had been having to change the setting by turning the shaft with pliers. Somehow, in the time between ordering and receiving the part, the whole assembly that contains the shaft came out of place (I am assuming) as the shaft is now flush with the hole from which it should be extending. Can you advise me what to do?
