Dryer cuts on and clicks but will not start
Dryer will power on but not start. Depending on the dryer setting it will click 1-3 times, it did this before I changed the thermistor but stopped and it started doing it again after I got the new control board.
I have fixed what I know wasn’t working but I’m at a standstill.
Error code TE1 I changed the thermistor and it was bad it was checked with a meter
Fuse was reading 0.1 and I believe that is okay
Control board would not read so ordered a new one the new one picks up on the meter so I know it works.
Belt is on nicely like it should be.
Should I keep trying to fix it or just get a new one?
Single mom don’t really have the money to replace it or pay someone to fix it so trying to diy it.
Hello, since you have already changed the main control there are just a couple of things that would stop it from running. The door switch, belt switch, and motor itself but with the clicks you are hearing I would suspect an issue with the PCB assembly.[AP6799342]. Unfortunately, this part has been discontinued so the repair cannot be done.
